Eagleseye pop
Thread starter- Joined
- Nov 3, 2024
- 10
Have a 2002 90hp 2stroke merc. Came on boat I just purchased that had been sitting a couple years. Would start but rough and die often and wasn’t charging. went through and changed oil in lower unit ( old looked good) replaced plugs, two new batteries, wires , coils , stator and trigger. Timing is spot on. Set carbs to factory setting (and have tweeked them some) compression 115 all three cylinders . Drained cleaned and added new gas to tank. Boat runs out pretty good but idles very rough! Charges now and will idle but very rough at idle and low forward no wake idle speed. When I come out of the hole it planes out and seems fine…….only thing I know left is carbs or reed valves?.. any ideas on how to troubleshoot before just continuing to replace parts……
