Evinrude 200hp missing hose?
mikec
Not having another engine to compare, and the<br />manuals dont seem to show it, I need your help:<br /><br />On my "new" (ie:used) 1992 200hp Rude, theres a small brass block and nipple which is mounted on the rear top port side of the block. A water hose comes from the telltail, is routed up and behind the powerpack, and into this brass block. On the outside of the block is a nipple which either needs to be plugged or connected to another fitting with a hose. Well... as u can guess, Ive found no other sister fitting for a hose. When running the engine, water of course sprays out of this nipple. So...<br /><br />1- Should it be plugged, or...<br />2- Can someone tell me the location of the mystery sister connection?<br /><br />Im thinking a plug may have got knocked off when they removed this motor from the other boat... just want to be sure.<br /><br />TIA.
Dhadley
Re: Evinrude 200hp missing hose?
Sounds like someone may have mistakenly "teed" in their water pressure gauge hose there. OMC used a plastic 90 degree fitting there. You can just plug it off although I'm not fond of a brass fitting in an aluminum block in the water passage. <br /><br />Good luck!
mikec
That makes perfect sense now. Ill ask the previous owner about a water pressure gauge. Thanks much.
Dhadley
A very good idea to get one. Just hook it up correctly to get accurate readings.<br /><br />Good luck!
