Trying to separate upper / lower gearcase.
Bueller
I'm trying to separate the lower and upper gearcase to get to the drive gears. I have a 1968 6hp Evinrude and I can't seem to separate the two. Any suggestions? I don't know who owned it last or what they used to seal it. Hopefully the norm. Would heating it cause any problems? Would it even help?<br />Please help!!!!!!!!!
vincent2
Re: Trying to separate upper / lower gearcase.
Would heating it cause any problems? Would it even help? I dont thing heat help,use a rubber hammer and hit under the joint,if he dont come loos, check if you forget somme bolts.also look at chifting rod.
hondon
This unit requires you to pull the powerhead to drop the gearcase because of the rollpin spring contraption at the top of the driveshaft.Not as scary as it sounds if all the bolts come out nicely.
