I have a 1970 Johnson 115 on a 14FT Swiftcraft Stiletto. The boat is used primarily for skiing. Can anyone tell me what the best size prop to use would be.<br /><br />Also, I've noticed that the spark plugs currently being used are NGK B9HS, the manufacturer recommends B7HS. Apparently the only difference is to do with how quickly the plugs dissipate heat. Is it worth changing to the recommended plugs? The ones in use are brand new.
