o"hook a brotha up"
Spur
Could someone please out of the kindness of their heart help me locate the parts and numbers for the following items.<br /><br />My local shop is talking out of both sides of their mouth and I really need to get this dang ole motor running.<br /><br />I need the part numbers and the businees to order from via the internet for:<br /><br />1959 5.5 Johnson Seahorse CD-16<br /><br />1) Carburator rebuild kit (with float, needle and seat)<br /><br />2) a fuel pump rebuild kit<br /><br />Thank you very much, I have been bird doggin these parts for a couple weeks. <br /><br />"Rookie"
ajp
Re: o"hook a brotha up"
Try www.maxrules.com <br /><br />The MasterTech. A great website for help on old engines.<br /><br />Arlan
alcan
Hi spur<br /> The omc part # for your carb kit is 382047. My parts manuals show this motor originly ran a presure fuel system. So if it has a fuel pump it was converted. I can't give you a # if I cant see it. These parts you seek are comman parts. You can order them thru Napa or Any OMC dealer. Rember in the outboard busness these parts are inexpencive not free.
Spur
alcan, I have heard this pressure tank deal, what exactly is it?<br /><br />Maybe thats the problem, but I was told by someone (cant remember who) that it wasnt.<br /><br />It runs fine in a horse through but when I took it out it acted funny and then just died.<br /><br />Its got a black "snuff can" shaped unit thegas line go into. Is that the fuel pump??<br /><br />Thanks
G DANE
Yea Spur - it should be the fuel pump, if the fuel line from tank takes a little break there before continuing to carb. Pull the hose from carb,, while tank is connected and primerball firm, and try to pull the cord a couple of times. ( you should be in shape now ! ) Does it squirt a little fuel out ?<br /><br />If you order parts from theshadconnection.com you can see the kits, and a partslist for several models, to make sure you get the right. I dont think Iboats have theese sets, or it would be natural to get it here of course.<br /><br />Good luck
G DANE
Spur - pressurized tank is an older system where a hose leeds a little exhaustpressure to tank, another hose then leads fuel to motor. No fuel pump needed, but not as safe -a line leak means fuel everywhere !!. The old motors can be rebuild by attaching a fuel pump from a newer motor.
almost retired again
Spur;<br />It's easy enough to tell if you have a pressureized system or not, if you have two hoses going to your fuel tank, then it's a pressurized system. If you only have one hose it's non-pressurized and must have a fuel pump.
Grizzly
I have three of the original fuel pumps for that era. A newer style is available from local dealers.<br /><br />SPUR: Give this guy an email.-G.
Grizzly
Spur, did you email Bobber? I feel like he could be a good source of information and/or parts. In the mean time,I went treasure hunting on ebay.I don't know if any of this will help,but sometimes it takes a lot of ore to produce a nugget. My time is somewhat limited right now-I'm trying to get a Mercury running before spring gets here. But if you and me and the iboats experts stay after it we'll have you on Lake Granger by early spring. Send me some hog brains.......<br />Life is good! -G.<br /><br /> OMC Johnson Evinrude fuel pumps parts 3386833 $31.01 5 Feb-26 23:06 <br /> Omc Johnson Evinrude fuel pump old new 378805 $10.00 1 Feb-26 23:12 <br /> Omc Johnson evinrude fuel pump pt#385748 $17.17 3 Feb-26 23:16 <br /> OMC johnson evinrude fuel pump pt#385781 $10.99 2 Feb-26 Don't know if any of these help you could see if any of the pictures look familiar<br /><br /><br />Evinrude/Johnson Impeller Kit 5.5, 6, 7.5 HP <br />Item # 1807145530 This fits yours, I would at least try to get the part number.<br /><br /><br />JOHNSON EVINRUDE TUNE UP KIT 3-40 H/P 1952-92 <br />Item # 1806692206 <br />JOHNSON EVINRUDE TUNE UP KIT This kit consist of 2-580148 points 2-580321 condensers,This kit fits <br />, 5 1/2 h/p-1954-64<br /><br />To view these just type the ebay number into the search box. <br /><br /> <br /><br /> <br /> <br /><br /> <br /><br /><br /> <br /><br /> <br /> :eek:
Spur
Dang dude! You found all that on Ebay???<br /><br />You hit the honey hole, I need to russle around on there and find some of those goodies.<br /><br />Sweet find thanks!
Spur
I have another really dumb question.....<br /><br />whats up with the OMC, what does it mean. Do several brands fall under that catagory???<br /><br />Like Johnson and Evinrude, I dont get it yet, fill me in
wimpie
Spur this has nothing to do with your question, but I love your quotation at the bottom of your Post. Hope you are as truely blessed as I am by posting on this board. You can definatly get an answer for what ever you want to know.
Grizzly
Spur, I think this will be the carburator kit we're looking for. Brix Enterprise; part #382047 $13.59. http://home.earthlink.net/~brixent/omccarb.htm <br /><br />I'm not an authority on OMC and there are many here who are. I hope they will correct me and give you better information. OMC is the worlds largest maker of outboard motors. Outboard Marine Corporation was formed in 1935, when Johnson Motors merged with Evinrude, Elto and Lockwood. OMC has been credited with many engineering firsts, including invention of the modern stern drive by (then) OMC chairman Charles Strang. Companies they own or have owned include Gale Outboards, Lawnboy, and Cushman Motor Scooters. Most modern Johnson/ Evinrudes were produced as "twins", only the names were changed to protect the innocent (sorry, I couldn't resist). Hence the name "Johnnyrudes". This would be like Chevy /GMC pickups, or Norton/ Matchless motorcycles. Didn't mean to say so much to say so little. Got to go work on a Merc. Did you ever drop a 1/2" socket down the exhaust tube? Bummer, man. :confused: <br />Life is good! -G.
Spur
Thanks guys, im fixing to dig into the ole girl. I have to study for a state surveying exam in between the fun. That motor is calling my name right know though.<br /><br />Have a great weekend! :)
