Re: Wanted-info on prop protectors or savors
Just be careful, <br /><br />In rocky areas, aluminium props are great because they are cheaper then a gearcase..<br /><br />If you put a big solid steel prop protector on, and you have a big hit, you may end up totaling the lower half of your outboard.<br /><br />If you do make a solid one, give it a couple of "weaker" points so they break instead of tearing the outboard off your boat or the leg off your outboard.<br /><br />( I have seen the results of that sort of thing a couple of times, and once to myself.) I got home with my Suzuki 40 tied to the back of my boat with ropes and the throttle stuck on fast idle with tape.<br /><br />rgds<br /><br />Frank
