motor adjusted all the way in cavataion plate still abvoe bottom help!!!!!!!!!!
nbru21
adjusted motor all the way its still is to high what can i do to lower the motor. its a 9.9 johnson. can get any prop bite mid to hig throttle
Fouled Plug
Ensign
Re: motor adjusted all the way in cavataion plate still abvoe bottom help!!!!!!
You could possibly extend the shaft of the motor. Is it currently a 15" (short) shaft? Another option is a bracket on the transom to allow the motor some adjustability.
nbru21
can i notch my transom??
kev_79
notching you transom might weaken it, but that would be up to you. How high is is above the bottom of the transom. If not too high, a 4 blade prop may solve the prob. Good Luck
nbru21
I CALLED WHERE I BOUGHT THE BOAT AND THEY TOLD ME I COULD NOTCH THE TRANSOM TO 1 FIRST BRACE. WHICH WOULD BRING ME TO WITHIN A 1/2 INCH OF THE BOTTOM OF MY BOAT. DO YOU THINK THAT WILL DO IT????
MercilessMike
WOW, notching the transom could lead to alot of work, also mya be an issue when backing down or extreme following seas. I would think a mnaul jack plate would be far more cost effective, Would also have benefit of fine tuning the height. Andother plus is not messing with the structural integrity of the transom. <br />Manual jackplates are not that expensive, compared to time to cut, CORRECTLY, reglasing and redrilling mounting holes.<br /><br />Best of luck whichever you decide!<br /><br />MM
Dhadley
Nick -- you've got the same question running in at least 3 different posts. The difference in shaft lengths is in the mid section, not the lower unit. Get the extinsion kit and go have fun boating! Don't notch the transom (for ALL the reasons stated). In / out adjustments have nothing to do with the X dimension (up / down).<br /><br />Good luck!
nbru21
BEING NEW TO BOATING I FOUND OUT THIS WEEKEND TO GET AN EXTENTION KIT IS MY BEST OPTION. I HAD NO IDEA IT WAS NOT PART OF THE LOWER UNIT. THANKS FOR ALL YOUR HELP
