oil/gas mixture old evinrude
JB
Re: oil/gas mixture old evinrude
Howdy, Fortyfive. Start with 24:1 (1 qt./6gal.). You might be able to use 32:1, but try it very carefully and at any sign of overheat go back to the 24:1.<br /><br />Red sky at night. . .<br />JB :)
fortyfive
thanks Howdy.I dont know how long it has been since this engine has been ran.I took out the plugs and sprayed some WD 40 in the cylinders. while I had out the plugs I checked the sppark and had a strong spark on one and none on the other.I think its the points but that is a small thing.It also seem to have high compression which is good should run good. Tanks!!!!!!!
