I have just acquired a 1948 Johnson TD-20 5HP outboard, but have no operating/servicing info about it. the motor seems to be in great shape and has good compression. The previous owner said it started and ran recently.<br /> I'd like some basic info about it before I attempt to start it (with the lower unit in a tub of water):<br /> What's the right fuel/oil ratio?<br /> What's the right spark plug type and gap? Point gap?<br /> How do I check/change the lower unit lubrication & what oil or grease should I use?<br /> I assume this has a water pump/impeller; where is the pump located & how do I check to see if it's working? Where are the water intake and exhaust ports located?<br /> What initial settings should I use for the idle mix needle valve adjustment and the rich/lean knob on the top?<br />Any help would be greatly appreciated.<br />
