Agreed especially if there are no engines in there anymore. Had an old penn yann years ago (30+) that had it in the hull bottom was a PITA even with straight 6 ...Silverton also installed their garboards on the bottom of the hull, installed from the inside much like how Scott showed. Imo, that's the way I'd do it.
Why not two drains, one in old boat vertical and one standard in the new section? I assume you will put a pump in both so that means a drain is appropriate there as well.OK . . . thanks for the comments.
I'm more concerned about the weep hole (sleeve) that will be between the 2 pieces (hull & extension). I believe surrounding it in 5200, as mentioned may do the trick for longevity.
As for the garboard itself . . . I could go either way, but if on the bottom (of the keel), I'd want it to be recessed in case of a run-ground situation. . . . but where things are at, that train has left the station, unless I'd want to do a bunch of re-work. ()
2010 . . .Oh, and when was the last time you ran around?
No . . .you going to fill that pocket with foam and skin it?
