2020 150hp possible fuel related issue
pittpete
4th time out after purchasing boat with 2020 150hp with 260 hrs and full tank of fuel.
Previous owner never knew he had a fuel water seperator but always rtreated with marine stabil.
I replaced it before going out on my 4th trip.
I cruised around for around an hour+ between 4-4500 RPMs.
Slowed down to around 3000 RPMs while returning and the engine hesitated when I throttled back up.
Kept it at 3000 for a few minutes and tried again and she hesitated.
Kept it at 3000 while limping home for sround 10 minutes or so.
Tried one more time to accelerate before entering marina and she was fine.
Sound like water in fuel or a restriction that some how passed through?
Down to half tank of fuel and no alarms on dash?
Thanks
nola mike
Could be a lot of things. How old is the gas? Stabil isn't magic. Did you check the filter when you changed it? Might want to take another look. Running off a fresh portable tank is always pretty high on initial troubleshooting steps.
pittpete
Purchased it 2 weeks ago.
Im sure theres some of last years fuel mixed with new since the guy didnt take it out much this year.
The old separator filter contents didnt look terrible when I poured it into a clear container.
Should I pull the new filter if it happens again?
Thanks for the suggestion on the portable fuel tank.
New to 4 strokes👍
airshot
Didn't look terrible....? Any concern at all should have been a call for further testing. As you noticed, walking back to the dock after your motor quits is not a viable choice. Your safest bet is to pump out the fuel tank and check for water which be be near the bottom. Another option is pull the water seporator filter and see how much water is in there. If you not sure, pour a small amount off and see if it burns. I have saw so much water in fuel that it would not burn at all. Saving a tank of fuel is not worth the potential damage to your motor. Pay very close attention where you buy your fuel, in most cases, the fuel your buying is not good as many stations do not properly test and maintain their underground tanks. Fuel needs to be treated before it is contaminated not after.
pittpete
What I meant by didnt look terrible is I dumped the contents of the fuel separator into a container. It looked clean with no particles in it. I let it sit for half an hour and saw no separation in the container.
I appreciate your response.
My engine didnt quit, it hesitated at 3000 rpms twice after running for over an hour.
Im going back tomorrow for further testing.
I will update in hopes my post can help someone in the future
jlh3rd
what color is your fuel line? If it's grey, replace it.
dingbat
Make and model of outboard?
Most modern outboards have fuel moisture sensing to alarm for water in the fuel
Ok, let step back a bit….the motor ran well up until the time you changed the fuel filter. Now the motor hesitates upon acceleration?
If you put the two together, the obvious concern would be a vacuum leak given the problems manifests upon acceleration. You need to go back and revisit your filter installation.
pittpete
No grey fuel line.
This setup doesnt have the sensor for water in fuel.
The motor ran fine after I had changed the water separator. Cruised around for over an hour and hesitated much later returning to the marina.
Took it out today and ran fine at all RPMs.
Had plenty of 2 strokes over the years but this is my first 4 stroke.
Is it possible a particle or something clogged up an injector and momentarily caused my issue?
Jeff J
This kind of reminds me of an issue we had on a 150 EFI a few years ago. It took someone really good with the diagnostic computer to identify the throttle position sensor as the culprit. He tried to walk me through the numbers and their relationships on the screen but I wasn’t tracking any of it.
airshot
Are there more filters inside the cowling ? Often we change the obvious ones we can see but sometimes their are others inside buried that no one looks at. Just a suggestion here...
Jeff J
The only fuel filter I can think of on a Mercury 150 EFI isn’t visible. It’s accessible via yellow handle on the right side of the power head. PITA. It uses press-to-connect connections which helps with installation but can be a challenge to disconnect, especially the outlet hose.
