Replacing Risers/Elbows and Exhaust Manifolds on a Ford/OMC Cobra 5.8 Ltr
KM7
Sounds like you used a generic hose and not one shaped for this application. I could use the existing hose, which would get me 2/3 of the way there and then add a straight section to go the extra 8 inches to the opening, then a 90 deg. fitting going into the manifold. Because the existing hose is shaped to go around the accessories on the engine, for example, the power steering pump, it would fit better. What are your thoughts?
Lou C
Do you have a pic of what your OEM set up looked like? I think with these hoses the main thing is that it doesn’t get kinked & restrict water flow….
Lou C
And...are you sure there isn't a pipe plug in the front and rear of the exhaust manifolds? This is how all the other Barr manifolds I have seen are, you remove the front pipe plug and use the hose fitting for the 3/4" ID hoses, you can use the rear one to drain it for winterization. The ones on top, might be for casting reasons, or perhaps for the exit on a full closed cooling system, but I'd be really surprised if there weren't pipe plugs on the front and rear.
For a raw water cooled system, which is what most boats have, a top inlet for the exhaust manifold does not make sense.
KM7
Lou or anyone.
I see that you: "First thing I did with my Barr conversion. After I took the paint off, they were just about perfect…"
I also have Barr manifolds. I am cleaning off the paint from the mating surfaces. That is a lot of work with a sanding block and a paint scraper!!
What did you use?
Can I use a wire wheel on a drill if I'm careful? That seemed to work very well on the head.
KM7
You were right! There is a hose port on the side, about the same place it was on the OEM manifold. Now I just need a fitting to screw into the port that will attach to the hose. Headed to the hardware store now ...
Lou C
Don't your old manifolds have that fitting? Mine original ones fit the threads in the Barr manifolds.
Ahh just checked them, looks like the nipple for the hose was part of the casting.
Mine came with these:
see the 90* fitting?
Lou C
About the mating surfaces I just used a razor blade scraper carefully. Then very light sand with medium grit sanding block.
KM7
I was wrong. The hoses for the water come into the manifolds at the ends, just like on the original. Both ends have threaded holes to accommodate the port or starboard side. I purchased 2 stainless steel 1 Inch to 3/4 inch threaded/ Barb fittings.Screenshot 2026-09-13 114429.png
KM7
New problem. The bolt holes in the exhaust manifolds do not line up with the bolt holes on the risers! I will return the aftermarket risers and look for resers that fit !!
Lou C
If you got Barr manifolds get Barr elbows. Can’t mix ‘n match brands. Better off just getting a whole Barr kit if they make it for your engine. Marine engine.com sells them for sure; the place they get them from is kinda local to me so when I buy em I don’t pay shipping because I can just pick ‘em up (Riverhead Long Island NY).
KM7
Thanks, Lou,
That is a good plan, going with Barr for everything,
KM7
I found 2 distributors that sell Barr manifolds. InboardOnline.com 877-327-7175 and Seaway Marine 425-412-4006.
I will be getting prices from them
The Barr P/N is OMC-20-913784
Lou C
The place where I got mine is Lighthouse Marine in Riverhead Long Island. Probably makes sense to pick the closest place to you due to shipping costs, the parts are kinda heavy.
KM7
The Exhaust Manifolds the boat shop swore were the right ones were not !!! They were BARR P/N FM-1-83 Ford SB. The gasket surface was not the same size as the original and therefore did not match the risers. ExhaustManifoldDimensionsOriginal.pngExhaustManifoldDimensionsBarr.png
KM7
Another boat shop said the right part is: OMC 1 3852347, and they can get it from LandNSea. Another option is marineengines4less.com. The manifold they have, they claim to be a match to Volvo Penta 3852347, but the manufacturer is GLM. I have heard that it may not fit. Do any of you have experience with either of these parts or suppliers?
Lou C
The only aftermarket I have used is Barr Marine for the Chevrolet engines and these fit and worked perfectly.
Lou C
And unless the manifolds & elbows were made by the same manufacturer you can’t mix one manufacturer’s elbows with another’s manifolds for the reason that you found. When an aftermarket company says it replaced the OEM part numbers for the exhaust they are talking about the whole assembly manifold & elbow, not individual parts.
When they say "replaces" what they mean is that their assembly (manifold and elbow) will bolt up to the engine cylinder head and the exhaust outlet will line up with the rubber exhaust hoses and down pipes, that's it, they are not direct copies of the OEM part. Same reason why you have to use the manufacturers gaskets between the elbow and the manifold. It's possible that some are an exact copy, but impossible to know without actually comparing like you did in the pix.
Horigan
On the hose fittings, I would get the 90 deg elbow version, like the one shown in Lou's picture. Going through this right now on my 302 Ford EFI OMC.
Lou C
Mine came with those originally when I had the batwings.
Getting back to the mismatches, Barr is the company that casts both Mercruiser and Volvo OEM manifolds from what I hear, but their aftermarket product may be made slightly differently. Always use a matched set the manufacturer's gaskets.
KM7
Why use a 90 Deg fitting for the hoses into the exhaust? That aims it up. The thermostat housing where the hose will go is on the right or left, horizontally. Leaving that alone makes it nearly identical to the OEM layout and the original hoses fit perfectly.
