Re: 65 HP JOHNSON - WHAT YEAR???
Upon further investigation I can find no quarter sized disk with numbers. Not really sure where the power head is, I believe it is on top with the teeth and timing marks on it. It has, however been put in a different case. The case it is in has a hole where a choke went and is now being used for the wiring to the control box with the throttle lever and a toggle for the choke. There is another knob for something that is not connected inside the case. It has all been changed. The tank is now a portable 6 gal. It has a tank under the deck that is not being used. The boat is a Bayliner 16 ft. I think the original engine was a Merc. I had already ordered the manual, was a little spendy, but hopefully will be of some use. Still not sure what I have just hope I can make it run. Thanks again! Leont
