Need help old Evinrude
EX TECH
I have 1955 7.5 fleetwin with a 2 hose tank. Has anyone installed a fuel pump to adapt single hose tank? Or have any suggestions?
alcan
Re: Need help old Evinrude
Hello ExTech<br />Yes this can be done. Its can be a good way to go. <br />Did you have a question that wasn't coverd in your last post? If you will do a search on this board, you will find lots of imfo on this subject. Let us know If you have a speicific question.
EX TECH
Hello alcan<br />My only question is where to attach the pump hose?<br />I have 2 pumps. One has a return spring and one <br />doesnt. Hooking them up to the crankcase breather<br />proved useless, even after removing the check valve. Should I drill and tap one cyl cover to<br />increase the pulse. If I cant adapt a pump Ill <br />just have to find another tank, but I wont give<br />up without a fight.
alcan
Hi Extech<br /> I like your aditude. Try not to fight too much, thats no fun. In order to mount the fuel pump to the by-pass cover (intake side of block) you need to have a cover with the bosses cast into it. You could drill and tap your cover for a hose fitting. It's much easier to use the one on the intake manifold, as described in the above post. If you drill your cover you will still have to stop-up the hose fitting on the intake manifold.
