Hi,<br />I'm glad that I have found a forum on outboard engines. I have a 1982 90 hp Evinrude.<br />The problem I am experiencing is starting to confuse me. While idling thru the boat harbor (2 to 5 minutes) the buzzer is fine, however soon as I throttle up (1 to 3 minutes) the buzzer sounds. However, after I checked to see if the engine was overheating (took cover off to touch the heads,it was only warm) the engine started up and ran fine the rest of the day, no buzzing sound. Changed the thermostat to no avail, same thing happened What should I do next. Kazumi
