Fishbusters
Ensign
- Joined
- Apr 20, 2002
- 921
I have a starcraft Pontoon with an 87 50hp johnson outboard on it. I am having problems with shifting. I can get neutral and forward or neutral and reverse but it will not shift from forward to reverse all the way if. I can get one or the other but not both I get just enough to grind gears but not engage. I pulled the cable and the shifter works just fine mannually. If the control box is in or out of gear I can hold the cable in one hand and I find about 1/8 of an inch play in the end of the cable. It is almost as if the inner cable needs tightened. Is there and adjustment in the control box end for this or do I need to replace something? If I need to open the control box I will I have replaced the ignition switch in the box but never looked at the shifter. I realy don't want to open it up unless I have to but I will.
