eric fairbanks
Thread starter- Joined
- Apr 23, 2002
- 34
Well, here we go. 90 hp '89 VRO V-4 powering 17ft lund tyee. End of last season no oil alarm would come on at low (idle) speeds, but would only do it occasionally. This year it has done it a few times--usually turn motor off for fear of damage then start back up to get home and will not do it for awhile. Anyway, another problem--related? I don't know. Recently it has no power out of hole bearly gets on plane and struggles to do so. And has gotton very hard to start(this started last season). So I replaced plugs, fuel lines, primer bulb and filter, fixed a gas leak at the tank sending unit. Still no power to get on plane! This boat used to get to 40mph at 5,500 rpms, know only 30mph at 4,700 rpms! It may start easier now--but I can't tell now--hence 3rd problem--I broke off one of the plastic nipples coming from the primer and had to plug it--so now only able to prime two cylinders! Any ideas on trouble shooting the power loss problem? I can fix the primer(probably need to replace). And the oil alarm if it gets worse I will just eliminate the VRO. This is a nicely rigged walleye boat that I use alot but take care of (it looks new) But if the motor is toast I will derig it and sell it. One last thing the motor since I bought it two years ago has made a "clicking noise" at idle speed--it doesn't do it any other time--or atleast you can't hear it. I have accepted it as normal--but I know my old boat '90 70hp johnson vro did not do it.
