I have a Johnson 70 which is having problems. When it is not in gear it idles at 1100 to 1300 rpm. When put in gear at idle it goes to 900. The manual says it should idle at 600 to 700 when put in gear and the timing is adjusted on the lake in gear at idle speed. <br /><br />After inspecting the engine I found that the throttle linkage was not set up properly. The throttle arm was not set against the its idle stop. I adjusted that and the throttle cam and throttle cam follower to .010inches. I took it on the lake to see if this made any difference and to check the idle timing. The idle timing was set to -4 degrees and the spec was 4 (ATDC). I changed it to 4 and adjusted the idle mixture. It idled ok but would not accelerate at all. It bogged big time when trying to advance the throttle even out of gear. The idle was 900 rpm after all of the adjustments, the same as before. I changed the timing back to as it was. <br /><br />The thing that is concerning is the manual mentions if the idle is too fast there could be a leak to check induction system for air leaks. How do I do that and is 900 rpm too fast for this motor in gear? And the timing is 8 degrees off and runs good above 1500 rpm? Any chance of damage? <br />I am going to buy a tool to insure the timing pointer is at the correct location so when it indicates it at a particular timing it is correct. This tools checks top dead center of piston # 1.
