'95 Johnson 130-"aspirator pump"
ratltrap
Can anyone tell me if this is supposed to be freeflowing or restricted as far as water circulation is concerned?Water shoots out small hose good when not connected,only dribbles (out pee hole) when connected to "pump".Also, if it is not supposed to be restricted,can it be cleaned out or do I need to buy another?
clanton
Re: '95 Johnson 130-"aspirator pump"
I would back flush the valve with water/air.
ratltrap
:) Many thanks Clanton!I'll try that.If it doesn't work is it ok to try to clean it out with a wire or drill(very carefully and operated @ slow speed?
