1988 50hp Johnson O/B tilt/trim
metalmantis
Was wondering if there are rebuild kits around for a prestolite tilt and trim pump on a 1988 Johnson 50hp outboard and what is the bleed down time recommendation. When up on plane every 20 to 30 seconds I have to hit the trim buttom to keep motor at proper position. No leakeage around actuator or outside leakage noted. Not even sure if that is normal operation.
Bob_VT
Re: 1988 50hp Johnson O/B tilt/trim
Get the manual. As per the manual I have the Prestolite should not leak down more that 100-200 psi. If it is a hydraulic problem there are plenty of hydraulic repair places you can get it rebuilt (or do it yourself). I won't swear to it but a rebiuld kit must be available. There are dealers on this board who will be able to answer that or call your local one.<br /><br />Bob
clanton
You have a photo of T/T motor? Is T/T motor and pump located on transom beside motor?
metalmantis
I don,t have a picture, but yes it mounted on right side of outboard.
JOHNNY S
1988 50 hp evenrude tilt trim selonoid schematic
I need the wiring diagram for a 1988 50 hp evenrude power trim on the selonids. I took some of the wires off and cannot figure out how to put them back on.
Is the selonoids grounded to the case?
