Zero compresion on 1 cylinder
dsteers
OK, I've gotten down to the root cause of my problem ('90 Evinrude 110). No compression on <br />cylinder 4. Meaning Zip. Nada. Zilch.<br /><br />Any hope for a miracle cure? I just bought it and it ran OK on land, but in the lake only 2500 RPM. Once it went to WOT, 50+ MPH, then back to no power. <br /><br />Sticky reed valve? Stick rings? Little spooky things hiding?<br /><br />Please help prevent a nasty situation withthe seller.<br /><br />Thanks,<br /><br />Doug
Joe Reeves
Re: Zero compresion on 1 cylinder
Doug..... It's time to remove that cylinder head to inspect the piston, cylinder wall, etc. Sorry to say that there's no miracle cure.
Fouled Plug
Ensign
Any aluminum deposits on that plug? Zero compression makes me think of a hole melted in the piston. :(
