76 Johnson 75hp Stinger
willj
I want to replace prop shaft seals that let water into lwr unit. I was told to remove lower hub. I loosened 3 smaller interior screws in hub with rubber seals. Now what should I do, use gear puller to pull hub out or does inside hub unscrew somehow. Aluminum on aluminum doesn't seem like gear puller would work. Can't find book to explain procedure.
MGuckin
Re: 76 Johnson 75hp Stinger
Most OMC dealers stock this manual or can get it next day for you. Or try kencook.com.
