daronlittle
Thread starter- Joined
- Jun 23, 2002
- 4
Friday , we were out in boat and I was wakeboarding and after several runs, I had just gotten pulled up (motor was in a heavy load) and all of a sudden it was as if the key was switched off (hasnt started since.)<br /><br />The motor is a 1972 Evinrude 60 hp outboard. I checked the battery (good) and I am getting 12 volts to the ignition module. Also I get 12 volts OUT of the ignition module when cranking on the motor. however I get NO fire to the plugs. I have been told that the iginiion module may be bad , but before ordering that 120 bucks piece I thought I would ask here. I was wondering is there a magneto under the flywheel (big wheel on top of motr) that could have a pin that has sheared? or should I try the ignition module first?
