johnson 70 hp tracker89
mar576
motor is hard to start,when started it runs fine with a good stream, But on occations it gives an alarm and runs very rough,after shutdown it runs normal again any input is welcome thanks.
D
DJ
Guest
Re: johnson 70 hp tracker89
mar576,<br /><br />I assume this engine is oil injected???<br /><br />THe alarm you are hearing may be an oil alert.
Joe Reeves
Mar576.... If that engine has the "slow" feature, (white wire with black stripe at heat sensor in cyl head), and the alarm that you mention is a constant steady beep, the engine is overheating. If so, inspect/change the water pump.
