NEED A POWER PACK FOR EVINRUDE 125
MEINAMA
DOES ANYBODY KNOW WHERE i CAN GET A GOOD DEAL ON A POWER PACK FOR A 1972 EVINRUDE 125 MOTOR. MINE IS GETTING NO JUICE OUT THE BACK SIDE.
Joe Reeves
Re: NEED A POWER PACK FOR EVINRUDE 125
Amayel..... I have one left in stock for $235 which includes shipping, but run the following test to make sure your pack is faulty.<br /><br />(Battery Capacitance Dischage Powerpack Test)<br /><br />Purchase a small 12v bulb at your local automotive parts store (the 12v bulb is to look like a flashlight bulb, not a headlight bulb). Solder two wires to that bulb, one to the side of the bulb (ground), and the other to the positive point. <br /><br />Remove the spark plugs. With the key in the on position, make sure that you have 12v going to the pack at the terminal block (purple wire). Now, connect the ground wire from the bulb to any powerhead ground. Connect the wire from the positive point of that bulb to the powerpack wire that is connected to the coil wire on the terminal board (blue wire). <br /><br />Crank the engine and observe that bulb closely (CLOSELY!). If that bulb glows even the slightest bit, the powerpack is okay. It may be a very dim glow... just so it glows! If it doesn't glow, the pack has failed. <br /><br />Keep in mind, that type powerpack (Battery Capacitance Discharge) demands a top notch battery of at least 70 amp hours. Any less will, in time, cause powerpack failure. (ReevesJ32@aol.com)
