1989 Johnson 140hp Water in Tank
Neokoros
I have a 1989 Johnson outboard engine. 140hp V4. Last year I must have picked up some bad gas. Before I got my boat on the water this year I emptied the gas tank and found that there was about 5 or 6 gallons of water in the tank. I cleaned all of it out and put new spark plugs in and a new gas filter. I still cant get the frigen thing running. I checked all the plugs and they are all firing. I cant figure out why it wont start. Someone please help me. I have put all new gas in the boat and a bottle of dry gas from Napa. I dont know what else to do. Please help me. Thanks
JB
Re: 1989 Johnson 140hp Water in Tank
Howdy, Moses.<br /><br />Your fuel pump may have drowned. Though it doesn't seem likely, you may also have 2 gummed up carbs.<br /><br />Squirt some fuel mix into the carb throats and try to start it again. If she tries to run, overhaul the pump and both carbs.<br /><br />Good luck. :)
Neokoros
There is more to the story to. Last year at the end of the summer the boat started to have problems running and the very last time I went out it would not run at all. I decided not to get it fixed till spring. I took the boat to get winterized and supposedly they did but the problem is that in order to do that the boat has to run. So I dont know what they did or did not do all I know is that I drained the gas/water mix, put all new gas and dry gas in plus drained the carbs and everything else and still it will not fire at all. Please help.
