Gas Flowing out of Carbs when idling
cacioa
I have a 1988 225 Evinrude. The boat runs fine when it over 1 or 2 knots. When I go any lower or in neutral it will cough, and stall, then gas begins to come out of the cowling. Does anyone have any experience with this kind of problem?<br /><br />Any advice would greatly be appreciated.
JB
Re: Gas Flowing out of Carbs when idling
Sounds like at least one misadjusted or stuck float.<br /><br />Have you pulled the bonnet to see where the fuel is coming from?<br /><br />Good luck. :)
cacioa
JB,<br />Im not too mechanically inclined. Other than just taking off the 12 or so bolts, Once that comes off is there anything else that has to be taken off once it is open?<br /><br />Thanks
JB
Sorry. I wasn't clear. I meant the engine cover.<br /><br />Are you interested in fixing this yourself, or do you just want to be able to evaluate a wrench's input? :)
heyitstim
jb , i really need some advice from you on a 1985 merc, 35hp. i am having carb problems, think you may be able to help. will you respnd to my post , it was done on july , 7th look for heyitstim. thanks
