markjewell
- Joined
- Jul 2, 2002
- 17
Hi folks,<br />1961 evinrude 18 hp. Is there a "standard" amount of up/down play when the lower unit is all together? I know that there is a shim on the back<br />of the pinion gear, but they only make one size shim, and the manual only calls for one of these standard size shims.<br />I have 2 lower units. One has about 1/4 inch play, but the other on has about 3/4 of up/down play!!! I would think that this pinion gear on the end of the driveshaft would NOT just "float"<br />there!!!<br />The pinion gear is retained on the end of the driveshaft with an e-clip, which is there.<br />I just find it hard to believe that this driveshaft can just move up and down willy-nilly.<br />Any input would be greatly appreciated.
