I have a 1972, 65 hp Johnson, 3 cylinder. It was not in the water at all last year. I started the engine on the trailer this year and the engine appeared to run fine. I put the boat in the water, started the engine and it idles fine at 1200rpm's. When I throttle up, at around 3000 rpms, it "chokes" out. It bogs down and the rpms drop quickly. It will run fine at 2200rpms at about 5 knots. As soon as I throttle up, she boggs down. I changed the gas..cleaned the filter screen...added a fuel injector cleaner, changed the plugs and idled for agout 20 minutes. Still the same. What can it be? What else can I do?? Please help!<br />Lou
