I've a 2001 25 Johnson on a 17' Lowe aluminum bass boat that acts like the hub is spun. Here are the symptoms and what I've done to date. It engages fwd or rev ok. It'll run at any throttle position for a while without any problems. After a few min's at hi or full throttle the engine revs, and the prop looses power and the boat steers left. Back off of the throttle and it'll run ok until the power is up again. I don't usually run at WOT for long, tending to stay at about 75-80% when running at high speed. Based on reading posts in this forum I've purchased a replacement prop and had the OEM prop reworked. No change in symptoms using either prop. What else might cause this to occur?<br />Thanks, HC
