Old Evinrude. ID and Start problems.
noelmac
Hi! An old couple gave me an old Evinrude. Serial # 18304A100G499. The cover says 25HP but I<br /> checked a Website and was told that it's a 1973 18HP. Can someone please verify? I installed<br />a recoil and tried to start up I rand for a few seconds and shut down. Now the crank is difficult to turn.<br />It is really hard to pull start. I'm new to all this and I can't afford to put a lot of money into this Any<br />advice you can give will be appreciated. Thanks Noel
fireman 757
Re: Old Evinrude. ID and Start problems.
You say it ran for a few minutes and shut down. Sounds like it either overheated or you ran straight gas through it and the cylinders are wanting to seize. you need to run a premix of 50:1 with a high quality two cycle oil. You may want to run the first tank at 32:1 if it has overheated. This will give additional lube for your pistons. It will smoke more but will help.
noelmac
Thanks for the reply FIREMAN 757. Yeah I ran a 48-1 mix and when it started, it smoked a lot but shut down almost immediately. It started a second time. Same thing. Then it was difficult to turn the crank. I have to tell you I have limited 'any kind of engine' knowledge. Isn't water supposed to come out of the outlet? All I saw was lots of smoke. I don't think it has been run for a year. I did confirm that it's a 1973 18HP Evinrude.
steelespike
Try taking the plugs out and cranking.Should turn <br />pretty freely.If it seems to drag or be stiff<br />with plugs out there could be more serious problems.<br /> Sounds like you need to find a friend with some engine experience before you can do much trouble<br />shooting.If it shut down allmost imeadiatly you<br />probably have a fuel supply problem.If the plugs are wet and gassy the carb may be flooding.<br /> You need a ser. manual if your short of cash try the library they usually have manuals for reference.Has anyone shown you the correct way to start your motor?If you can it would be good to clean and check the gap on your plugs.<br /> Good luck.
noelmac
Thanks Spike! Plugs out and still stiff to turn the crank. You're right I need someone experienced to check it out. Also the plugs were oily at the gap. You all should know how helpful this forum is even for 'fools" like me. All the best, Noel
