'81 Evinrude 90HP Power Tilt and Trim
mbriggs
The motor for my power tilt and trim sounds like it is working but the engine won't go up and down. The engine is stuck in the 3/4 up position; the pistons won't move up or down. I took the boat out of storage and started to lower the engine but it stopped after a few seconds. Where do I start?
V156
Re: '81 Evinrude 90HP Power Tilt and Trim
You may able to answer your questions by doing a search at the top of the page. I would start with the fluid. Is it low? <br /><br />Dutch
mbriggs
Dutch,<br /><br />Thanks for the feedback. I did the search but wasn't sure which of the postings applied to my problem. The best I can tell is that it is probably a hydraulic fluid issue. There are some postings that reference the reservoir and hydraulic fluid but I'm not sure what it looks like; nothing is clearly identified. What am I looking for and on what part of the engine? <br /><br />Thanks!
V156
First things first. Before anyone can help you we need the year,who made it,hp,etc. Some t/t's are different in appearance. One major thing you <br />MUST do (unless you want to run to the shop and wait) is get a manual for your motor. THAT will save you a lot of grief and money. The more knowledge you have about your investment the better off you'll be.<br /><br />Dutch
mbriggs
Dutch,<br /><br />I bought the boat second hand but it looks like the tilt and trim is original with the engine. The engine is a 90 HP Evinrude (1981) Model E90MLCIM and the serial number is J0002248. Looks like I'll have to pick up a manual. <br /><br />Thanks for your help.
