power loss under load
delsol
my i35 johnson idle fine compression ok put in gear and it will run fine for a while the stall as soon as i put in gear .when i try restart it always starts up but you have to fight it to get it in gear to go 1500 rpms tops to get back to dock when i spray carb cleaner in carbs it will sometimes in a couple of minutes get back to normal then die out again rebuilt carbs and cleaned jets just dont know my local dealer is booked for 2 weeks
Baja18
Re: power loss under load
Check the connection on all plugs and I would replace them also. Also check the pump as soon as you stall again and see if it is still tight.
delsol
pump is always hard after promblem
