FreeBeeTony
- Joined
- May 15, 2002
- 3,997
The problem I am having is the engine seems to miss at low speeds until the boat gets on a plane. Once on a plane it runs great.......I don't have a tach but it seems fine at WOT. I have cleaned/rebuilt the carbs, replaced the water pump and thermostats, rebuilt the fuel pump and ran a can of OMC engine tuner through the primer solenoid. It can't be a fuel problem bacause all the lines and tanks are new (just bought the boat and motor this season). I have also replaced the plugs and cleaned the connections on the ignition coils. Does it sound like I have a problem with the ignition advance? It seems like the problem only appears at the beginning of the throttle up. I don't have a timing light and I have not touched the linkage. I do have a manual, is there a quick way to check the sync/link?<br /><br />Thanks in advance............
