I have an 88spl Johnson 1994 model on a 17ft center conlsole. My problem is when I get up on plane engine runs for about 3-500 yards at wot then cuts back to 1100-1500rpm. Engine does not die!! Just cuts back rpm. After this happen you can bring throtle back to idle then go back to wot on plane. Then will happen again. <br />It is not a fuel problem. I can disconnect the kill switch wire (black and yellow) at power pack and engine will run fine. Engine has good **** flow. Could this be the water temp sensor acting up? or something in the power pack or the strator going bad?
Any help is appreciated!!!
