Carphunter
- Joined
- Aug 11, 2002
- 2,061
I have a 1981 Johnson 115, model# J115TLCSA. I found out recently that one of the coils was bad, so I replaced it, but there seems to be an electrical problem. There are three connections on the coil, the ground strap, the high tension lead (which connects to the spark plug), and the primary wire. The problem seems to be in the primary wire. I can switch the primary wire from the top coil to the bottom and get the bottom cylinder to fire, but the top wont fire, if I switch it back again, I can get the top cylinder to fire, but the bottom wont fire. So I am thinking that one of the primary coil wires are bad, or one of the wires going to the power pack, or maybe even the power pack itself. What do you think? It looks as if the motor has been running on 3 cylinders for some time, (I just recently purchased). I was told that the coils were the correct replacement parts, even though they appear to be slightly different. I have had the boat out only a couple of times, and it sure runs great on 3 cylinders!<br /> Thanks for the help, this is really getting frustrating!
