V6 seems to lose half after running fine for 40 minutes, with no overheat indication (long way from home). Can only restart by shifting quickly into gear and then it will run only within narrow RPM range, suggesting that the only half running is the half that is suppressed by the shift suppression switch (or equivalent in this model). Is there a shop manual for these models available? I'm guessing based on old 85 manual. I would guess power pack if there were still two, but I assume these models have only one. Any advice on simple troubleshooting would be welcome
