Parts for Johnson Tiller control.
shaneb
a few of the gear parts in my 1982 25hp johnson are worn so that I am not getting full throttle and there is lots o' slop. <br /><br />Does anyone know where I might be able to find some used replacements? <br /><br />Can I get them new through a dealer? <br /><br />Any help is appreciated. <br />Thanks, <br />Shane
Reel Appeal
Re: Parts for Johnson Tiller control.
Hello Caddoducks,<br /> Parts for your motor should still be available through a Johnson dealer.Alot of parts are interchangeable with newer motors.Good luck.
sloopy
I don't think its the tiller thats wrong
shaneb
Uhhhh, well, thats what I call it anyway. Its the throttle control attached to the motor. <br /><br />There are a series of gears at the base of the motor where it meets the handle. <br /><br />There is a gear with a cylinder attached and a pin that sticks through the side of the cylider. Where that pin rubs is visibly wornout so that the throttle turns a good bit before it begins to push on that pin. therefor the handle runs out of throw before the carb gets to full throttle. You can turn the handle all the way and the butterfly still has another 10 degrees or so before WOT. <br /><br />Does that make more sense? <br /><br />I have always called that handle the tiller control. Is that not the right term? <br /><br />Thanks, <br />Shane
Reel Appeal
Ahhh,I see your problem Caddo.Would a larger diameter bolt replace that pin to take up some slack?If its accessible,you may be able to drill a slighty larger hole and install the appropriate bolt/lock nut.But,will it fit? I would see your dealer anyway for that gear part first.If not available,then there's an idea. :p
BHM7952
We closed our dealership but still have many parts, props, service manuals, parts catalogs and msc. for these older engines. Please include model number HP and list of items needed.<br />Email: linda@nu-z.net
slow_boat
Retired Man...<br /><br />OMC factory manual fo a Johnson 9.5 9r-69s for sale?<br /><br />Thanks
