I'm working on my 1974 135 Evinrude. I'm replacing my 135 heads with 115 heads, because of broken bolts in the head cover. Cylinder 3 had a small amount of oil with water, less than a thimble full. I think because the head bolts were loose. Piston #4 was chewed up at the top as well as on the head. The gasket was not perfect. It had a couple of small holes at the top o cylinder 4 and the bottom of cylinder 2. With the exception of 4 the cylinder walls are pretty good. 4 has a small scratch that I think would be fine if I sanded it down. <br /><br />Can anyone offer advice?<br /><br />Thanks,<br /><br />Greg Hodges
