48 johnson spl
DOGHUNTER
at full throttle engine surges in and out continously and when i come off of it a little it runs fine and also idles well
Yepblaze
Re: 48 johnson spl
Sounds like she's a little thirsty for fuel.<br /><br />Like perhaps a fuel starvation problem. <br /><br />Sometimes if you give it a little pump on the fuel line primer bulb while it's happening, and it goes away it might indicate:<br /><br />Air leak in fuel line to engine connector or fuel line to fuel pump<br /><br />Fuel filter needs cleaning<br /><br />Fuel pump needs service<br /><br />If pumping the bulb doesn't seem to help it may have debris in the main jets and or float bowl semi restricting the metered flow.
