Re: 1970 9.5 hp Seahorse Johnson won't run
Blazin<br />yes Johnson did make a 9 and 1/2 up until 1973 when the 9.9 and 15 came out.<br />You said you did a conpression check but did not give the numbers. The more info you share the more likely someone can help you. When you rebuilt the carb are you sure you Got float set right and set the low speed jets right?? Have you changed the plugs and gaped to .030??<br />From what you say sounds like fuel. How old is Fuel?? If you pull plugs and squirt a little fuel in put plugs back in and try to start what happends?? A weak spark can look ok with plugs out but blow out under compression. I would start by squirting some fuel in carb. If it starts then starts to die squirt in a little more. If it runs that way you can be sure it is fuel. Check for water in fuel, the inline filter, make sure the low speed jet is adjusted, make sure the high speed jet is open, make sure float is working and needle is not sticking, and make sure float is set to proper level. If you give the guy here the info they will get you on the right track without any info just a total guess.
