how to troubleshoot ignition on 89 johnson 175
te779h
i start the motor let it run and turn it off and it will not start it has no fire. i let set for a long time and check the fire and it has fire i try to start it and it will not start. i check the fire again and no fire. i think it is the power pack but dont know how to troubleshoot it to find problem please help thanks.
clanton
Re: how to troubleshoot ignition on 89 johnson 175
You need ohm meter and peak reading volt meter.
te779h
claton i have a ohm meter what do i do with it
clanton
look for connector between stator and powerpack will have 4/6 wires 4 wires will be brown, the connector marked A B C D E F. Check the AB and CD termial on the stator side, your readings should be 480 or 985 +-25 do this and post readings. Check magnets in flywheel, you should be able to do this without removing flywheel. Locate black/yellow wire on powerpack disconnect, check spark, if spark returns, defective harness or switch. keep bumping to top I may be out for a day or two.
te779h
Hi clanton I checked AB and reading was 1.041 and BC was .000 I could not find black/yellow wire so I disconnected the wire harnest at the big red plug and still no fire thanks.
te779h
clanton I checked CD and had a reading of 984
clanton
My post was wrong, should be termial AB and CD. I edited the post. The AB side is out of spec, the CD side looks ok. One side fires 3 cylinders and the other side fires 3 cylinders. you realy need a peak reading meter or adapter, see www.esitest.com. I think the stator is gone, and you may have other problems. plug it all back together.Set your meter 3/400 volt AC scale, check pack output to coil with all wires connected, cranking rpms. Then do same on DC scale post readings.
