This motor is RKL-30 '68 40 horse. Will start with (gasp!!) starting fluid. Will not happen again. Belongs to brother. Our father suggested the ether. Fuel gets to the carb when you squeeze the bulb. Not sure if it is getting any farther.<br /><br />Does this motor have points, condensor, etc? Does it have a fuel pump? I have heard of a shifting shaft on other motors, would this have one too? It is the Electramatic 40. The wire(s) extending down into lower unit, would these be for the electric shift? How can we test the shifting if it is not starting?<br /><br />Where would some of these items be found? Most specifically the fuel pump? Can this pump be rebuilt? Carb? Should either be tackled rather than buying new/factory rebuilt?<br /><br />Will do the carb cleaner trick. Maybe that will all that is needed as the motor sat for quite some time. If that does not work, do you have a "to do" next scheme? How are reed valves checked? What symptoms would one have if they are in need of replacing?<br /><br />thanks a bunch<br />Billy Bob
