Steering Problem :(
lynch_00
Please help... I have a 85' Evinrude 150 with a older teleflex sh5098 rack and pinion dual cable steering system on a 85' Winner Bass boat. Here's the problem... It will turn great to the left(about 3 turns) but when I go to crank it to the right the steering wheel goes about a half turn or so and stops... It stops like that's all it has and the pinion gear is maxed in that direction... I'm wondering if it's a cable issue or if their is some way to re-center the steering so that the right turn can have some of that left steering... Any help would be appreciated as I'm completely in the dark on this issue... <br /> :confused:
DP
Re: Steering Problem :(
This is only a wild guess but I would suspect that the rack has chewed up teeth and it is new steering time.
