Changed plugs and checked all fuel and replaced all plastic clamps with stainless and new fuel filter. engine idles good and revs good in neutral. pulled plug wires one at a time, rpm dropped on each one. ran ten minutes on hose rechecked plugs, three looked a little oily, one really bad, started up again, rechecked that plug, rpm still drops when I pull the wire put old plug on the wire could see spark when I touch it to head.<br /> Engine is way down on power under load WOT then back off to atleast half before engine starts to slow. Tried choke at WOT almost killed it. Runs alot better with cowl off, not great but better,<br />butterflies are all the way open at full throttle.<br /> I'm at a loss. Any suggestions appreciated.
