Re: Can't Get MAX RPM'S
Hi, FAI.<br /><br />Hmm. Good spark to all six. Pumping the primer doesn't help. Perhaps we have one high speed jet plugged, perhaps we have one plug not firing under load.<br /><br />We still need to find out if the problem is fuel or spark related, though it could be reed related.<br /><br />Try spraying extra fuel into each carb throat while running under load.<br /><br />No change? Try pulling each plug wire, in turn. Then running her up again. If running on five is slower than you have been getting, that is a good cylinder. If you still get to 5000 with a plug wire off, you have found a bad cylinder.<br /><br />Let us know what you find.
