Re: Power in 1 plug
BigJoe.... Remove the spark plugs. Rig up a spark tester whereas you can check each s/plug wire to see if the spark will jump a 7/16" gap.<br /><br />If, as you say, you do not have spark (or very weak spark), remove the black/yellow wire from the powerpack and retry the spark test. If you now have a good strong blue flame on all cylinders, you have either a faulty ignition switch or a short in the wiring harness.<br /><br />If with the black/yellow wire off, you had good spark, you can test the ignition switch by reconnecting the black/yellow wire to the powerpack, then removing that black/yellow wire at the back of the ignition switch, then recheck the spark. If you have spark, the switch is faulty. keep us informed.
