veteran evinrude 15
alone
One of my friends give me an 15 hp Evinrude outboard, painted grey, 'FİFTEEN' written on the front side of the hood. It's shaft is short.<br />Firing up is vey hard, generally it doesn't give response to throttle, sometimes it is running well<br />but generally it is working choked. But the choking system is working well. What are the specialities of spark( cold, hot etc.)how can I understand the make year of the engine? How can I troubleshoot on it?
Joe Reeves
Re: veteran evinrude 15
Alone.... You should check the compression and spark, and also the lower unit lube. Do not remove a philips screw if it exists in the lower unit skeg as that is a shoulder bolt shift lever pivot point screw.<br /><br />You can check the copmpression with a gauge (prefered) or simply feel that the compression is sufficent and even on both cylinders. If with a gauge, it should approach 80 to 100 psi.<br /><br />The spark should jump a 1/4" gap on a magneto system and a 7/16" gap on a CD ignition system (with the spark plugs removed).<br /><br />Your explanation of the problem indicates that you have a fouled, clogged, gummed carburetor. If so, the cure is to remove, clean, and rebuild it.<br /><br />To find out exactly what the engine is, we will need the model number. It should be located on a plate on either the left (port) transom bracket (the bracket that attaches to the boat), or on the front of the swivel bracket (the bracket the engine turns/swivels on). There may also be a core plug (looks like a small quarter size freeze out plug) on the powerhead itself with that same number.<br /><br />Once we know that number, you can obtain a manual, gain information about the engine, order the proper parts, etc.
alone
OK Joe,<br />Thanks for detailed advisory, I will try for repair and tune up. I can do whatever ı want to a chevrolet V8's Rochester but I am very rookie on outboards, two cycles, and oil mixturing to the fuel... I will take the serial number and write again.
Joe Reeves
Alone..... I do not need the "Serial Number". The "Model Number" is what is needed to determine what you have. However, list all of the numbers on the plate and I'll sort them out.
alone
engine serial number of my old 15 hp evinrude is:<br />15702AB3382,<br />I would be grateful if I could learn about spark plugs,ignition, make year, and online sources about tune up and repair..<br />thanks
alone
Hi Joe, thanks again for your kind cooperation.<br />The only number I saw was 15702AB3382,<br />if it is not enough to understand the engine please warn me. Sorry for English...
Bear
Hi alone!<br /><br />From that model number I got this: <br />#15702 15HP year 1967. <br />From here:<br /> http://www.marinshopen.se/guide/omc/evin6.htm <br /><br />According to this web site there was no 1967 15HP:<br /> http://mitglied.lycos.de/old_omc/e_1967/evin_1967.html <br /><br />Try to find some similar here:<br /> http://mitglied.lycos.de/old_omc/oview.html <br /><br />What do you mean by veteran, 1920, 1940 or 1960?<br />As you know we need the year first.
alone
OK Bear thanks,<br />I used veteran name to describe it as old.<br />Maybe I can be misused it, sorry..
Bear
No need to be sorry. I'm just trying to find out what you have. Maybe it isn't from the 60's at all. It can be vintage, veteran or just 25 years old. <br />It doesn't look this old this does it?<br />
alone
yes I think it is like as a 25 years old engine.<br />And not old as the one in the picture..
Joe Reeves
Alone..... Model number 15702 does not exist. However Model number 15704 does, which is a 1977 15hp Evinrude. Is it possible you misread that number?<br /><br />Is the hood metal or fiberglass? Little by little, we're getting there.
alone
Hi Joe,<br />One of my friends wrote it and I checked twice<br />the number on the plate is 15702AB3382,<br />the hood is made of fiberglass.
Scoop
From what I understand the grey ones were made for the Navy.
alone
At the front there are three switches,<br />left: the choke lever<br />mid: air fuel ratio <br />right : low speed control
alone
yes scope I think so , it's color is faded grey
