old evinrude
dt3909
no water out of head on evinrude mod.4447 s/n 91184 5 hp. pump is working and when i hook up a hose to the flush fitting still no water comming out thanks
Bear
Re: old evinrude
4447 Evinrude <br />Year 1952 <br />7.5HP @ 4000 rpm<br />12.4 cu.in. = 203.2 ccm <br />2 cyl <br />47 lbs. = 21.3 Kg <br />Prop 8 x 8 , 2 blade <br />Gear ratio 13:20 <br /> #4447 1952 7.5 hp Evinrude picture <br /><br />There is a tube from the lower unit to the powerhead, right?. I think it isn't in the right position at the powerhead. Do you have a manual?
Backlash
Re: old evinrude
I don't believe there's supposed to be any water coming from the head (tell tale) on that motor. Does it overheat? If not, don't worry about it.<br />Backlash
Chinewalker
Re: old evinrude
There should be a water outlet midway up the exhaust housing in the back - round hole, pees straight out...<br />- Scott
dt3909
Re: old evinrude
hi guies thanks for the hels droped the lower unit. water pump and plate is ok. don't see a copper tube. -thanks bear- no manual oldest one i can find is 1956. any ideas where to look for this manual doug
steelespike
Re: old evinrude
D T, I was on ebay the other day.Put in outboard manual. Something like 30 pages came up maybe your manual is there somewhere.<br /> Also www.kencook.com does reprints of manuals.
dt3909
Re: old evinrude
thanks for all the help. I sent e-mail to both places. looks like i will be able to get a repair manual thanks again doug
