Re: FASTSTRIKE???????
OK THIS IS WHAT HAPPENED TO MY EVINRUDE. MY FOOT WENT OUT IN JUNE. OK I WAS TIGHT ON MONEY SO I BOUGHT A USED ONE INSTEAD OF A REBUILT ONE . WELL THE *******S I BOGHT IT FROM SOLD ME A WORTHLESS FOOT, IT WAS WORE OUT AND NO MATTER HOWI ADJUSTED IT IT JUST WOULD STAY IN GEAR. SO I TRIED TO GET MY MONEY BACK AND THEY WOULDNT. THIS WAS LIKE A WEEK AFTER I BOUGHT IT . WELL THE NICE GUY THAT WORKED IN THE SHOP IN THE BUILDING , HELPED ME OUT AND GAVE ME ANOTHER ONE AND LET ME KEEP THE WORE OUT ONE . WELL HE SAID THEY WERE THE SAME SHAFT LENGTH, BUT IT TURNED OUT THIS ONE WAS A LITTLE LONGER AND WHEN I BOLTED IT UP IT PUSHED THE CRANK UP. WELL I DIDNT KNOW IT WOULD DO THAT. BUT AT THE TIME WE DIDNT KNOW IT PUSHED THE CRANK UP BUT I KNEW SOMETHING WASNT RIGHT SO I TOOK IT OFF WITHOUT RUNNING IT . MY MECHANIC DID SOME MACHIN WORK ON THE SHAFT AND SHORTENED IT TO WEAR IT FIT GOOD AND SHIFTED PERFECT, BUT WHEN I RAN IT (NOT KNOWING YET THE CRANK HAS BEEN PUSHEDUP) IT STARTED MAKING A METAL RUBBING SOUND AND IT WOULD DIE. IT WOULD CRANK BACK UP BUT IT WOULD DIE AND I KNEW IT WAS IN BAD SHAPE. WELL I TOOK IT BACK TO THE GUY AND HE TOLD ME THE CRANK WAS WARPED AND THE BEARING SURFACE WAS DAMAGED AND IT WOULD NEED REBUILDNG IF ABLE OR A NEW POWERHEAD. I JUST LOOKED ON THIS WEBSITE FOR A REBUILT POWERHEAD AND THE CHEAPEST PRICE I FOUND WAS 3200. AND I JUST GOT OFF THE PHONE WITH THE GUY THAT HAS MY BOAT AND MOTOR AND HE SAID IF I CAN GO AHEAD AND GET THE JOHNSON IT WOULD PROBABLY BE BETTER CUZ I WOULDNT BE SPENDING A WHOLE LOT MORE MONEY AND IWOULD BE GETTING A 4 YEAR NEWER MOTOR. <br /><br /> THANK YOU GUYS ALOT
